help me!!
South west utah
I wired in some trailer lights on my 91 fj80 yesterday and everything was fine until I took the nut off the positive terminal on my battery to attach a wire to run power to the trailer lights. After I got everything finished the truck won't start now. The strange thing is that with the ignition off and the key removed from the truck and the signals turned off it sounds like the turn signal is clicking for about 30 seconds, then it stops for thirty seconds then starts ticking 30 seconds and goes back and forth. Also there is a little red light on the dash that is flashing real fast and it has never flashed like this sense I got the truck and there is a couple weird switches that don't look original under the dash. This is really confusing. I am thinking maybe there is some kind of anti-theft on the truck that I set off. Here is a video of the light and signals ticking. Anyone ever see this happen before or have any idea where or what I should be looking for, Thanks.
Definitely a aftermarket alarm/anti theft device. If it were me and I didn't use the alarm I would carefully remove anything that wasn't oem under there. It would be easy to spot aftermarket from oem.
