I think is is transfer...at least
97 LX 450 with 140K miles.
I have loud grinding noise oryginating from TC. Happens only in reverse and High and under load (like deep sand). I can duplicate is by stepping hard on break pedal and rev. the enginne some. It will grind as I had broken gear and it slips (facing uphil with rear end would make car slip downhill).
Had car lifted and you can feel and hear that TC is the source. Both drive shafts do not rotate but grind can be felt as it is comming form TC.
I eliminated both drive flanges (new and looking good) and front diff as well(drains clean).
Reverse Low is solid. No issues. None.
Forward High and Low no problems.
I use tha car as daily ride with no issues. Higway speeds, city stop and go including reverse is no problem and TC is quiet. The best part is - I had this for nearly one year.
Local shop, in wich I do not have much of faith, wanted to replace TC for new one right away.
My thoughts are, possibly High Idler Gear stripped...and this is my un-educated guess.
I wish I had good shop wher I live but is remains a wish only...
Help me to troubleshoot...
