Help me with my CEL
Sonoma, CA
Website
www.myspace.com
So I got my '94 in early December, as I was doing the 45 minute ride home, the check engine light came on.
I took it in to get it smogged, and surprise, it fails. The smog check place gave me a code 71, no vacuum to EGR valve.
So I took it to Mudrak, and he did some tests, and he advised I replace the vacuum valve and go to a different smog place.
He also shows me how to turn off the CEL, and 3 hours after failing, I pass the smog test with the light turned off.
So I get the part anyways, take it into a shop since Mudrak is busy, and pay $90 for Steve for "R+R EGR solenoid"
Then the light came back on. And kept coming on. And kept coming on.
I take it into another shop, several months later, and pay 385 dollars to not receive what the code is, but instead get: "no vacuum signal to egr. Diagnosis revealed failed vsv valve. Installed replacement and operation is normal."
An hour later, it's back on.
Are those codes the same?
What else can I replace to make the damn light go away?
Did I have the same part replaced two times in 6 months?
Anywho. Thanks for reading, and possibly replying to my post.
I just turned the light off earlier today, but when it comes back on in a few hours, I'll pull the code via paperclip and see if it's the same thing.
:frown:
If it is the code 71 search using keywords "egr" and "code"
This particular code is very common and has been covered repeatedly.
