So the original owner of my truck had some sort of aftermarket setup, so I received the truck without the luggage rack installed and the bolt holes plugged. I would prefer to have it installed. However, Ive run into several snags.
1) near the front passenger side you'll see an antenna style magnet. Is this for the nav? I could leave it there, as its not bothering anything, but I'd probably prefer to put this back to factory original.
2) the middle section of the luggage rack brackets don't seem to go flush against the roof. In the pics you will see a significant gap, this gap still exists when the plastic moulding cover is on. It is very tight, not loose at all, but what am I missing here?
3) The previous owner also let the rear luggage bolt clip fall through/into the truck. Where can you access these in the trunk to push them back up without damaging interior panels?
I appreciate all the help. Sorry for the newb problems, but this luggage rack setup seems like an overly complicated install for something that I thought would be simple.
