Help me diagnose noise
USA
Diagnosing noise
I hear a moan noise only after making a right hand turn under light or greater throttle.
Does not happen on a right hand turn if I coast or very lightly feather the throttle.
Does not happen on a left hand turn under any circumstances.
The noise starts after the turn is complete and the vehicle has almost completely straightened out.
Sounds like "waugh waugh waugh waugh waugh" -- about 4-6 times, about once per second, and then goes away.
Changed power steering fluid using the method in the FAQ, but no joy.
Other things to check?
Spindle bushings, wheel bearings or brake pads would be my first guesses. Does the noise vary with speed or with the angle of the turn or with something else?
Thanks very much for your suggestions.
The 'moan' noise only occurs on the typical 90 degree turn or sharper. I tend to take such turns at similar speed and can't say right now if the frequency of the noise increases with speed. Every time I've heard it, the frequency seems about the same -- about once per second.
Next, I'm going to change the fluid in the front diff, transfer box, and rear diff. Trying the easy stuff first.
Earlier today I changed the power steering fluid.
A couple months ago I changed the AT fluid.
Using Red Line synthetics everywhere, except engine sump.
I had a similar noise and thats how it started, leaving fairly sharp turns, then if I let off hard into similar types of corner it would do it. In the end I limped off a mountain with it doing it under no certain circumstance straight, turning right, left accel decel...you get the point. turned out to be spindle bushing..Taking apart the front end is fun, might as well order up some bearings and races just in case. The spindle bushing can sometimes be cleaned up with emry, re greased and be just fine for how long I am not sure I have gone about 5000 miles and no hint of noise. To replace you replace the whole spindle IIRC.
Easy stuff first, here's what I've done so far to try to fix the 'moan' noise after a right hand turn:
- changed power steering fluid to Red Line D4ATF synthetic using the FAQ method.
- changed front diff and transfer case fluid to Red Line 75W/90 synthetic gear oil.
- greased steering knuckles with Red Line CV-2 synthetic grease with Moly, half tube on each side.
- greased all six zercs on drive shafts with Red Line CV-2. 5 pumps per slip yolk zerc.
- adjusted tire pressure to factory spec 32 psi. BFG AT tires are stock size, suspension is stock.
- couple months ago, changed transmission fluid to Red Line D4ATF using the FAQ method.
Observations:
- As I was removing the front diff fill plug, I heard air rushing in. Does this mean the front diff breather tube may be plugged?
- Old front diff fluid is green and somewhat frothy on top. Not sure what this means.
- Expected to put factory spec 3.0 quarts of gear oil in the front diff, but it took ~3.5 before it started to trickle out the fill hole.
- Still hear the moan: "waugh waugh waugh waugh waugh" 4-6 times, about once per second, at the end of a right turn.
- If I coast the turn or very lightly feather the accelerator I get no noise.
- No noise after any left turn.
>> The noise does not start until the turn is complete and the vehicle is almost completely straightened out.
Based on observations stated above, I suspect breather tubes are plugged.
I think this could create a vacuum, enough to suck grease from wheel bearings, past the seal, into the front differential.
Today I plan to clean the breather tubes and modify the tube's end cap by removing the flap. I believe this essentially reverts the cap to a 60 series design and eliminates restriction. In addition, I may extend the tubes higher into the engine compartment using 1/4" ID fuel hose.
As people here have said, I need to check the spindle bushings, wheel bearings, and brakes. Thanks very much for those suggestions!
Any other ideas for potential causes of the noise?
Just to clarify, clogged breathers would suck the moly grease out of the knuckles and spindle bushing, but it would have no effect on the wheel bearings as they run on the outside of the spindle.
96r50, good point. Thanks for clarifying that!
Dbarr4lsu, base line all your fluids as described in this thread. Changing each fluid is as easy as changing the engine oil.
Start by greasing the steering knuckles via the square inpection/fill bolt on the inner top -- 1.5 tubes of Moly grease per side (3 tubes total). Any excess will weep out the seals.
When you change the fluid in both diffs and the transfer case, replace the six 24mm bolt head fill and drain plugs with 10mm allen head versions. A couple bucks per plug. The bolt heads on the original 24mm plugs are too thin and easily rounded.
3 x 90341-18021 (10mm allen head magnetic drain plugs)
3 x 90341-18016 (10mm allen head fill plugs)
4 x 12157-10010 (crushable steel gaskets for differential plugs)
2 x 90430-18008 (crushable aluminum gaskets for transfer case plugs)
My current thought is that my problem could very well be related to a dry spindle bushing, as the good folks here indicated from the start.
I plan to fabricate the special spindle greasing tool that Beowulf made based on Cdan's suggestion.
As always, I am open to any other thoughts, suggestions, corrections, etc.
Spindle bushing is my vote. I just went through this because my dumb @## didnt replace them when I did the front end service. Had to tear down the front end and put new bushings in. I guess after 200000 miles they were worn to real bad
I'll post this on the other thread, but basically put another tube in EACH knuckle if that is what it takes. Don't hold back as there's no down side to over greasing the front knuckles - the grease will just come out the large sweep seals on the inner face of the birfield/axle tips. That's the spherical surface you can see under the truck that should be wet with grease at all times.
After putting a bunch of grease in, drive it on the freeway for a half hour at 70 to get the birfs/grease good and hot and runny so it flows out into the spindle area. A half tube is just a snack for that big birf chamber. Use a hand pump gun and pull the grease caps off the drive plates while you're doing it to encourage pressurized grease to go that way. I'd even consider using a bit of air pressure into the birf's fill hole to see if I could move grease gently out that spindle toward the (now opened) splines. Ideally, you should do this while the grease/birf is hot from running and of course all you need to do it park it hot and pull the center cap, then the grease cap and then apply a bit of steady air pressure. The goal would be low pressure, like a couple pumps of a bike tire pump. Too much pressure all at once and you might push grease into the center diff (which is already happening a bit from the plugged breather and is not the end of the world vs a siezed spindle bushing). So, what - 5psi ish?
Also, getting grease onto the spindles can be done with that clever trail fix someone used to swap a birf on the trail. Pull the grease caps, pull the O ring, pull the upper/lower knuckle bearing caps, pull the brake calipers, remove the 6 bolts holding the metal axle seal retainer on and pull the entire enchilada off (hub/steering knuckle/wheel bearings). The axle is hanging there - toss some grease down in the spindle, grease the axle shaft and toss it back together. This is what I'd also do if I had just rebuilt the front axle and forgot to grease the spindle.
DougM
Doug, thanks very much for that additional info. Prior to reading your post, I had wondered if it's OK to exceed the 3/4 full recommendation to try to solve the problem. Good to know it's OK to do so and the extra grease will just come out the sweep seals.
As an update, I thoroughly cleaned the diff breather hoses. Modified the upper end caps to remove restrictions. Also removed and cleaned the metal breather fittings that thread directly into the axle housings.
I'll take it for a half hour drive at 70 mph to get the hubs hot and help the grease flow into the spindle.
I'll add another tube of Moly grease per side with grease caps removed, for a total of 1-1/2 regular tubes per side (3 tubes total).
Also plan to fabricate this tool to push Moly grease from the outer front hub toward the spindle bushing:
https://forum.ih8mud.com/80-series-tech/199523-birfield-done-forgot-grease-spindle-what-now.html
