You say you checked fuses, but did you also check relays? For example, the ACC relay? You should be able to remove it and put a temporary jumper pins 3 and 5 according to 2004 EWD) in to see if that makes things work. I don't have my 2000 EWD with me. Does your rear wiper work? If not, that could indicate your IG1 NO 2 relay may not be working, which also powers the cluster gauges.
You said power windows aren't working, according to the 2004 EWD they each have their own fuse, so unlikely you blew all of them, but all those fuses trace back to the fusible link at the battery. If you can't get to that fusible link easily, but you have a multimeter/voltmeter, you can remov a power window fuse and test for voltage there, if no power lresent, you know it's something with your fusible link.
Really almost need to use the 2000 EWD and start tracing to see where you do and don't have power.
