Sorry for the long post, but I need some opinions!!!
A few weeks ago I went wheeling and was on a long downhill grade...of course I was going slow, but rode my brakes most of the way down the hill. Ironically, right when I got to the bottom, I hit the brakes to stop and my pedal went to the floor. When I pumped them in a panic, they came right back...I thought I was loosing my mind or imagining it...havent had a problem since...until this weekend. I went on another wheeling trip at MontEagle Mountain and again, was on a long slow steep downgrade and this time I was not at the bottom and suddenly I lost my brakes...I used the e-brake to inch to the bottom...once I got there, I noticed "smoke" from under the hood. Appears my brake resevior was overflowing from under the cap. I pumped the brakes and they were weak at best...so I decided to wheel in 4L 1st gear when I needed brakes...after about 10-15 minutes of giving my brakes a rest, it seems they came back and were there the rest of the day and havent had a problem since...
Someone on the trail suggested that I had boiled my brake fluid from riding the brakes on the downgrade, causing air in the line and the overflow was the air coming out...
Is this possible and if so, how can I keep from doing it??? The brake fluid does not come in contact with the brakes...it simply presses the caliper...can heat from the pad and caliper actually radiate into the brake line???
Smart Ass Pete!!!
