Help Identifying a Hose
Maryland
I need help identifying and sourcing a coolant hose in this picture. I have tried the Toyota Parts catalog, but it is not clear to me.
Much appreciated
Much appreciated
According to this thread (Link: here) that hose has been discontinued. Its not present on all models but I had it. When I overhauled my system I use just a standard green line gates coolant hose that was the correct ID/OD. I also took this time to bypass by the rear heater, replace and overhaul every coolant hose, and flush all the fluids. Those throttle body bypass hoses are just terrible to replace in the snow or in the field.
Edit: If you delete the pair system you can use the 95-97 style metal heater hose to eliminate one more rubber hose connection.
Well, that is not what I wanter to hear......ok, so i have to get a plain line.....
Just use some gates green stripe or whatever heater hose you prefer. Gates is proven to be the best.
Can't remember if that hose is 5/8 or 1/2. You can order both sizes by the foot on the link I provided. I used to think heater hose is heater hose but I ordered the gates green stripe at the recommendation of everyone on this site and its obvious it is a better product.
Thanks, just trying to figure out the diameter. I understand the constant torque hose clamps are a good idea too. --- Getting the beast ready for my daughter to take on a climbing trip to KY and WV. Not very green, but the oil roads in KY can be ugly.
Those constant torque clamps are pricey. I just use regular hose clamps. But everyone swears by the constant torque. I could never find them in stock. If I were you I would by a couple feet of half inch and 4 feet of 5/8. Then keep it in the rig just in case.
