Help Identify wires through firewall
Hi,
While wiring up a rear puma compressor on my new 80, I noticed a couple of cut wires running through the firewall on the drivers side right next to the big empty grommet:
Any idea what these are, and should I be concerned?
Thanks
Not sure what year your rig is but my 97 has a rubber tube going through that spot which I'm pretty sure is for the rear window washer.
Looks like some PO mess. Does your rear washer work?
It is a 95, you were definitely right, that is where the rear washer used to run. It is just cut and dangling there...
I pulled on the wires there, they are definitely not oem. There was one red and one black wire. Traced them back and they are spliced into one of the computers in the drivers foot well.
Gonna need a wiring diagram to see what they were doing, maybe a remote start or alarm...
Also the level sense switch on the master cylinder is cut right near there, I hate finding PO old improperly done modifications.
