Toyota OEM hub conversion on M101
With help from the forum, I have started work on an M101 CDN. I replaced the hubs with 6x5.5 in order to use FJ Cruiser wheels (aluminum). Problem is, the studs are not the same thread as OEM Toyota so I can't use Toyota lug nuts. The lugs that came with the hubs are "acorn" type and barely hold the FJ Cruiser wheel on and do a lousy job centering as they are too small. The Toyota wheel uses a lug nut with a spacer that fills that large hole on the the wheel when it threads on.
Nowhere seems to make that style lug nut with the thread pitch of the hubs I got from Southwest Wheel. Where would I go about getting new studs (Toyota OEM thread style) to press in to the hubs.
Any thoughts are appreciated. I have to get this thing going for spring camping!
