HELP Front diff removal. won't come out!
central Fl
i have factory e-lockers 1995 LC. i have every bolt out... i have removed the shafts.. what am i missing? its loose, but won't come out. the area near the elocker seems to be hung up. does it need to be locked to remove? if so what wire do i put the charge on? my wiring is not set up under the dash yet.
Im pretty sure it does need to be locked to remove up front.
Do You have an fsm handy?
Im not near mine at the moment but maybe you can download and search in here
For Sale: - 40, 50, 60, and 80 series FSM for a hell of a price.
You may also find the wiring info in some of the actuator 9V battery tests in the rebuild threads if someone doesn't chime in shortly.
ehhh i was afraid of that. whoever installed the actuator stuffed the wiring behind the actuator one installation so i can't see any of the wires to know which to put a share on to activate ehhh i guess ill just do trial and error until i get the right one.
You can remove the actuator (3 or 4 bolts I think) and manually move the shift fork. You might have to put the shafts in before manually rotating to make sure the collar moves where it's supposed to go.
I'm very surprised your rear diff came out unlocked. Check the bottom of your pumpkin and shine a light in the tube to make sure the shift fork and collar didn't fall out. I was pretty sure the shift fork had to be retracted (in locked position) in order for the 3rd to come out.
Congrats on getting the diffs out.
