Help for a Highlander
Help for a highlander....I have been having trouble with my washer spray...neither front or back washer spray systems work. They went out around October. Have been to a few to have it fixed with no idea on what is wrong....any thoughts for what might be going on.
Do you have an owners manual?
I would probably check the fluid then the fuse.
Could be the switch, fuse, any of the wiring along the way, the pump (kinda doubt it's the pump because I think there are two separate ones for front and rear) you could be out of fluid, or have a clog in the lines.
What do you have in the way of electrical testing equipment?
Welcome to Mud!
2x on raydouble's suggestion
also make sure the nozzles aren't clogged - just my .02
and welcome to mud :flipoff2:
