Help explain Stereo EWD
Texas
I'm trying to understand the wiring for the stock sound system so that I could decide a plan on how make upgrades.
I've pretty much figured out everything except the "R2 Radio and Player" connection (light blue box on the far right) that plugs to the "Stereo Component Amplifier" (aka the front amp). It also has wires that are shielded for some reason. From what I know, the stereo only has 2 connectors shown as R1 and R3. I might be dumb and the stereo actually has 3 connections to it. So, what is the light blue box shown on the wiring diagram?
Another question is if I was to replace the front amplifier and subwoofer amplifier individually, would reusing the old power wires be sufficient for new amplifiers or would it be better to wire a new power connection to the battery?
There are two options for stereo systems, the EWD shows BOTH and the vehicle is wired for both.
The R1, R3 connectors are for the option with an amplified head-unit with four speakers, although I think all of us got the 9 speaker system with separate amplifier, which is shown as the R2 connector.
The shielded cable is for the low-level (audio) signals to the amplifier.
Any upgraded amplifier would require a new battery wire.
Alright, I think I'm starting to understand what you're saying. If I was to unplug the amplifier on the stock headunit, I will lose all audio from my door speakers. Meaning, bypassing the front amplifier only applies to using an aftermarket headunit.
Do you think a new front amplifier would be an improvement? All of the door speakers have been replaced. Right now, the stock front amplifier drives the speakers sufficiently. However, the rear door speakers audio is a lot more quiet than compared to the fronts. The fronts overpowers the rear with volume. Is that normal? Fronts are Kenwood 6.5" 3-way speakers. Rears are Kenwood 4" and I think also 3-way from what I remember.
The factory amplifier normally drives 8 speakers front and rear. Once you've upgraded the speakers, a bigger amplifier really takes it to the next level. But if you want to keep the factory headunit, you also need to keep the factory amplifier. Think of it as a two-piece system.
The output of the factory amp needs to be converted to "line-level" with something like this: Scosche SLC4 Line Output Converter
The output of the "LOC" will then feed the new amp.
And yes, the fronts will overpower the rears.
Also, you'll need to disconnect the factory "sub"woofer amplifier, that will be overpowered too (acoustically AND electrically).
There is no good reason to take the speaker level ouputs of the factory amp and convert those signals to pre-amp level signals. The R2 connector, which is the only connection to the factory head unit, already contains pre-amp level outputs (the shielded wires). That said, in my opinion the factory head unit is outdated feature wise and more than likely no longer can meet the original specs and should be replaced when "upgrading".
The muting function is handled by the amplifier.
Without it you will hear loud "pops" when switching between functions, potentially damaging the speakers.
Outdated for sure. But then, isn't the whole truck? I still like bass and treble knobs...and solid front axles!
Just want to make an update on the low sound coming from the rear door speakers. My sound system is set up with 2 front door, 2 rear door, 2 roof, and a 'sub' speaker. I recently pulled down my headliner and unpluged the roof speakers, since the wiring diagram shows it wired in parallel with the rear door speakers. This solved the low sound coming from the rear doors, because I think the worn roof speakers were splitting the power from the amp with the rears. The roof speakers didn't sound loud and clear anymore
