Help diagnosing foglight issues...
Eicca
Professional Noob
Utah
Spent all afternoon wiring the dang things up and they don't work. Here are my areas of concern:
Power source. Bolted the supply for the relay onto the back of the alternator on top of the wire that comes from the battery.
Relay. Could possibly be shot. How to test?
Grounds. The ground from the relay is sandwiched tightly between the relay mount bracket and the body. The ground from the switch is bolted down in some random bolt in the side of the engine bay. The grounds from the lights are bolted down on the metal behind the PS headlight.
Thanks... Little ticked off that it doesn't work...
not sure abou the power wire.
as far as the grounds go, make sure the connection is good, not to much paint etc.
I'll clean up all the grounds, but guess what Idiot Boy Eicca here figured out!
Lane gave me a link to a site on how to test these things and I felt stupid before even getting out my multi meter. These blasted four pin relays have two power inputs. I'm so smart, the switch part if my circut is supposed to come from a power source, and instead I grounded it.
Anyway I'll come back to this thread if the relay ends up working but still no go.
Thanks for putting up with me, as always.
