Help debugging factory keyless entry
Utah
Bought a '97 a few weeks ago and it came with no key fobs. Looked under the driver's seat, and it has the RS3000 system. So I bought 2 remotes (the correct black ones) online. Followed the setup procedure found here and it recognizes both remotes. (ie I turned ignition to "on", pressed the green button on the side of the box for three seconds until the red LED on the dash stayed illuminated, and then pressed the button on the remote).
So here's the weird thing. The remotes will Unlock the vehicle, but they won't lock it. Closing the door and then pushing a remote button arms the security system (light on dash glows, horn beeps if door is opened, etc.), but the doors do not lock. However, pushing the button a second time unlocks the doors, even though they are already unlocked. Does that make sense? It kicks the door unlock solenoids even though the doors are already unlocked. Note that the door "lock" mechanism itself works just fine to lock the doors, whether tripped by the door switch or by the key. Just not by the remote button.
Don't know if it's diagnostic, but there is no piezo beep.
I downloaded Slee's troubleshooting manual for the RS3200 (not the RS3000, don't know if it still applies), but it doesn't have anything on this problem. I would love to avoid retracing all of the connections, but will do so if needed. Any thoughts?
Just to cover the basics, and I don't mean this to be condescending at all...
First, you know that when you program the remote only one of the buttons is used correct? The same button will lock and unlock the truck. The second button (depending on which one you programmed) is useless unless you want to program it as well for the truck (not much of a reason to do so) or happen to have another RS3000 system in another vehicle that you want to program the 2nd button on the remote for (I've done that - top button on mine are programmed for the LX and the bottom button is programmed to the 80 - The 80's fobs are programmed just the opposite)
Second, no piezo beep usually means the piezo has given up the ghost. You can replace it for cheap with one from Radio Shack etc.. I assume you already tried the steps to make sure it is "turned on" and it still doesn't make noise.
Third, the doors will not lock unless all of the doors are closed. If you press the remote button without all of the doors closed, the piezo will "beeeeeeep" at you but since your piezo isn't working you won't hear it. I can't remember if pressing the button without all of the doors closed will also trigger an unlock command or not.
Other than that I don't have any suggestions but best to rule out the easy stuff first :)
Thanks for the reply. Those were my first guesses, too. I reset the RS3000 and then started from scratch.
a) That should have gotten back to the default of having the piezo chirp "on". Don't care too much about that right now unless it is somehow interfering with the actual locking.
b) The remotes only have one button programmed right now, so that top button should lock and unlock the doors. It only unlocks.
c) All of the doors are shut tightly. And I am pretty sure the door sensors also think the doors are all shut because using the the key in the door can trigger all of the locks shut on all of the doors and tailgate.
Thanks for the thoughts. Is there a particular pin on the plugs I should be looking at? My hypotheses right now are:
1) The wire that carries the command to "lock" from the RS3000 to the truck has a break. Another wire carries the command to turn on the alarm just fine.
2) There is some kind of open circuit created by a broken piezo that causes the whole locking function not to work.
3) Some door sensor doesn't think that the doors are shut, so it won't allow the doors to shut. Don't think this is the case (see above).
Oooh, that's interesting. It works with SOME of the doors. I have been meaning to play with those switches to see if any are stuck. I recall seeing something about interior lights on MUD, so I'll do a search of the archives and take a look at that.
I guess I assumed the RS3000 uses the same sensor logic as does the door locking switches and key--those let me lock the doors. But if you are saying there is a different "door lock permission" logic that governs those switches and the RS3000, then that's encouraging.
Thanks.
Thanks.
I don't know about the RS3000's "logic" but what Jolly states makes sense...That said, IMO the system is pretty dumb...
Case in point, you get in, turn on the truck, and the doors lock (assuming you have the system set up to do so). Drive a bit, stop to get the mail and unlock the doors to get out but leave the truck running, grab the mail and pull into the driveway and shut the truck down. Doors are still unlocked right from grabbing the mail right? Get out, shut doors, and push the remote button and the system does what? It unlocks the doors :rolleyes: - To it, the doors were still locked even though you manually unlocked them. Or maybe both my rigs are just confused :hhmm:
So, what I'm saying is that I wouldn't put too much faith in the system having much logic :D
Solved! I took out the kick panel and dead pedal to look at where the RS2000 harness plugs into the LC's harness to see if maybe a plug had gotten disconnected. I fiddled around with the plugs and kind of worked them around to see if they were tight. Then sprayed electronics cleaner and electronics silicone lube. The system works now! Still not piezo beep, but it locks and unlocks normally. Thanks for the help.
