Help Code 71
CANADA
help, gotr a code 71 when the check engine light went one, i checked the regulator or valve...not sure....the one with the filter...it looks brand new. so whats next, what needs to be replaced, thanks
Tons of info out there on this. Quickly it could be:
egr mod
egr vsv
clogged vacuum hose
clogged port/passage in the throttle body
clogged port/passage in the intake manifold
egr valve
egr temp sensor bad or dirty
I would start with thoroughly cleaning the TB, passages at the intake, and replacing vacuum hoses. Next testing the mod and vsv. Next test and clean the temp sensor.
Search, tons of info.
well i was looking at my service/sales records from previous owners, and in the last 4 years the egr modulator has been replaced 4 times at toyota dealersships, well i took the modulator/filter thing is clean, so u think to make sure the hoses r replaced 1st then look into valve assembly
As MoJ suggested, search for more information. This topic has been covered in depth dozens of times with pictures of all the components and R&R steps. Include the keyword P0401 in your search. Use Advanced Search and restrict your search to the 80-Section. Read for a few hours then start the steps MoJ mentions above.
-B-
