This has been really frustrating. I removed the ignition barrel easily, had a locksmith match the barrel pins to a new coded toyota key, now i can't get the barrel to go back in.
The long arm is under tension and sits inwards in this position, and with the end in that position it catches on a ledge inside and won't go all the way in, going in most of the way except the last half inch.
WIth the arm under pressure in this position it goes in. I managed to get it to go in by adding a shim to hold it in place under pressure, but once in the shim won't fall out and the key won't turn. After hours of F*$&ing around with this I'm about to break something. I'm thinking either I'm doing something wrong or the the locksmith did something and the arm is sitting wrong.... the manual and youtube videos just show to put the key in ACC and insert the barrel until the pin clicks.
