Help brkae light switch
Evanston Wyoming
Website
www.badlandsexpeditions.wordpress.com
The night before I are ready to leave for the Land crusier Roundup my brake light switch goes out on my 1977 FJ-40. Any ideas of any other Toyota switches might work. So far none of the parts stores here in El Paso have anything. No way am I going to drive 500 miles without brake lights. Any idea will be welcome.
Please feel free to e-mail me direct at mep1811@aol.com
Mike TLCA 8009
Make sure that something is not preventing the contact in the middle of the switch from moving outward....or that something else is not going on...
I am not aware of another switch that will work in that application...it is pretty tight quarters...
Good luck!
-Steve
I just replaced my brake light switch got it from o'rilleys HI-LO. It took three switches to get one that wasn't broken before I got it but 3 was the charm. It camewith direct plug in and has not given me any trouble since 3 months. Sorry I don't remember the part order #
or get a ford starter switch, (big cheap momentary switch, any parts guy worth his salt will know what you mean), bootyfab a bracket to the brake pedal arm, wire it up, go to the roundup, and fix it properly later. that's what i'd do. any momentary switch really, there is a litte microswitch type that can likely be found at radioshack, that would work well too, takes less spring tension to operate, they're in everything from electrolux vacuum cleaners to ricoh wheelchair lifts.
