First off -- WELCOME
CDL - Center Differential Lock
There's a bunch of information in the
FAQ.
Simple version: The 80's in the US are full-time 4WD. There is a differential in each axle, and a differential in the Transfer Case (TC).
In a stock vehicle, when you shift the TC into 4Low, the CDL also engages (and the indicator dash lights up). This causes equal torque to be transfered to both drive shafts. This helps in low-traction situations because one tire on EACH axle must slip before you lose power to the ground. It can cause difficulties in high-traction situations because of drive-line windup.
Test it: Go to a dirt field and drive in a circle in high (CDL disengaged) -- you'll have a tight turning radius. Shift into 4Low (CDL engaged) and drive in a circle -- you'll have a slightly bigger turning radius. When you shift back to 4High, it *may* take a bit of driving for the CDL to disengage (this is caused by the windup). Now go to an asphalt parking lot and do the same test. You *will* have driveline windup. Drive in circles or 8's (both directions) after you shift back to 4High to help the CDL disengage.
The FAQ also has information on adding a CDL switch, and the "Pin-7" modification. With both of these, you'll be able to have manual control of the CDL in both High & Low, and maintain the correct shift points.
Additional Note: If you have "Lockers" (see FAQ), and you engage them with CDL, you'll have incredible traction, and also greatly pronounced driveline windup.
