Hey guys,
After exhaustively searching the archives, I decided to go ahead and post as I couldn't find the answer I needed. I am having some problems... currently my '92 with 194,5XX miles is sitting dead in a local parking lot where I managed to limp it to.
(Pertinent info: I have a brand new battery, and my alternator is a rebuilt Bosch unit purchased less than a year ago from a mud member who did a diesel swap.)
The symptoms are as follows: (In fairly accurate order.)
1-About two months ago I started losing my charge over night, so I replaced my negative cable and was going to do my positive when my dad suggested testing my battery. Was no good, so replaced it about a month ago. Now that we're up to date...
2-Now, with new battery and fairly new alternator I started noticing odd anomalies. Normally on start up, the volt meter jumps right up to a little over 3/4 and stays there till warm up (and idle drops a bit) were it drops to about 3/4.
3-Lately though, I'll be driving along and it will randomly drop lower, like nearly to the 1/2 way hash mark. When this happens, it will dim the lights, and lower the speed on the fan. And the truck even accelerates more sluggishly. Then after awhile it will go back up. I can't tell if there are any correlations with this and bumps or not.... It just seems random.
4-So... tonight was driving home and the volt meter dropped BELOW the halfway hash mark. Hadn't done that before. It would also cut out the radio when I put the blinker on, and it even stalled the car once when I had the radio, A/C, and blinker on. Went to start it, and it was not happening. Barely turned over. Had to get a jump from one of my friends and she ended up following my wounded cruiser to the parking lot where I left it. I took the battery out, and will charge it and hopefully drive it home tomorrow.
So... obviously something is wrong. None of the lights ever came on so who knows what that means. It has gotten worse, so I wonder if perhaps some grounding issue? But... I'm not sure. Thats why I wanted to get some ideas from you guys. Hope you can throw me some ideas here. I'll probably be trying to figure it out tomorrow. If anyone thinks it is indeed grounds, I'm not sure where they are on my FJ80, so if can throw out some general locations and what to look for let me know.
Thanks guys, Michael.
