So I'm putting these in, bouight them used so I don't have any instructions. I don't have any existing horn harness in my 71 and an aftermarket grant steering wheel. I've got the horns mounted on the DS using some brackets I made. The steering wheel looks like it self grounds to the steering column.
What do I need to do? (how is that for an open ended question. Both horns have 2 tabs on them, one should ground to the bracket-any idea which? the other two will run in parallell back to the relay (87), 86 goes ot the horn switch, 85 ground and 30 power from the battery. Does this sound right?
Anyone have a install wiring diagram they could post?? Thanks
