Heator Hose/Radiator Flow Question
Portland, OR
Which way do these two heator/radiator lines flow? I have a suspicion I have my radiator lines hooked up wrong to my vaporizer for my propane conversion. Currently I have the number 1 line as the "in" line and the number 2 line as the "out/return" line.
Couldn't find anything in the haynes manual or in the tech section. Any help would be appreciated.
LT
That's how mine is hooked up.
GL
Ed
So then I do have it hooked up right. I have the Y pipe hooked up where the flow is going into the heater core and then the other Y pipe returning with the cooled water....
So then it isn't my propane not vaporizing right.
Any ideas on why when my engine is all warmed up it starts mis firing? I replaced the coil in the HEI distributor and I put in some hotter spark plugs because propane needs a hotter spark. The timing is set to 13 degrees advanced which is right where it is supposed to be. I have a mechanical advance dizzy instead of vacuum.
The vacuum is good, i'm sitting at 19 inches of vacuum at idle and rpms are solid at idle and through out acceleration.
