Heaters no workie...
CreeperSleeper
Cascade Cruisers
Canby, OR
So I drove my 80 for the first time in months the other day. Everything was as usual until the sun went down and I turned on the heat... Nothing but cool air. So I turn on the rear heater... More cool air.
I'm thinking that this is caused by my Heater Control Valve crapping out on me, but before I spend the money on the part I wanted to see if there was something I was overlooking. And if you don't know already, this is in my 1997 40th Anniv., so it has the auto HVAC.
TIA!
Confirm the coolant level (look in the rad, not the overflow bottle). Others here have had issues with PHH leaking out a bunch, then there isn't enough coolant in the system to circulate through the heater cores.
Then look at the temperature control cable, make sure the end is moving when expected to move, and the heater control valve is at full open.
Dunno what else to look at...yet.
Good luck!
If the coolant level is OK, it could also be thermostat stuck open. How old is the Thermostat? I'd probably replace that first. (It's cheaper.)
Whoa...let's not replace any parts until they are confirmed as bad.
If the truck has coolant, is running at operating temp, then it sounds like a heather control valve or blend door issue. But since the rear heat too does not work sounds more like the heater control valve. You should be able to feel the hose, the outlet from the heater cores and if it's cold but the input is hot up to the valve then it could be the problem.
I suppose it too could be the control head as well. Should be fairly easy to figure out in anycase.
Move here to Texas and you won't need a heater. If mine broke, I would never know it. I run the AC in January.
He'd have to change his tyres for the slippery arm-a-dilla road kill as opposed to tha sticky skunks 'round here. ;)
I figure I will move to Texas during the upcoming second Civil War. :bang:
I'm okay with that, as long as I don't have to go back to Toyo's! LOL
