Hello. I have a problem with my heater. When turned on the rear heat works great and the front doesnt, so I know that I need to flush the system.
But the biggest problem is that someone replaced a hose sometime ago (ive only had the 94 fzj80 for 10 months or so). I noticed that the hose clamp that was installed with the new hose blocked the arm actuator that moves the value open or closed. Well I moved the hose clamp to allow freedom of movement, and now the actuator wont move when moving the temp on the HVAC. I manually moved the valve to allow heat and thats how I found out that the front needed a good flush. I need to know how hard and how much it is to fix the actuator that moves the valve. Any writeups or howto's on this?
I did search but only found the solution of flushing the system. Any help would be great. Thanks in advance.
Jason
P.S. its been snowing and in the teens tonight and 20s in the day..... We are cold.
Jason
