Hey was just wondering what the difference between the the two settings on the heater pull knob on a 68 fj40 is. On mine I cannot hear or tell a difference. Thanks
IDave said:If the fan is running in both positions and truly at the same speed, then it is wired funny.
Standard wiring sends power directly to the fan at the hi (first notch out) setting, or to a resistor (looks like a black handle on the blower) on the low setting (switch pulled all the way out), which cuts the speed back.
It is not uncommon for the resistor to have died by this age (37 y/o for your truck!), in which case you only have the high setting. Replacements are available for the resistor.
. Thanks for that!Degnol said:Dave, I never knew that first position was "high" and second was "low". Thanks for that!
Ed
