Heater Problems fixed???
Lincoln, New Brunswick, Canada
I have been having electrical problems since I got the HDJ81 three years ago. I have been slowly fixing them a little bit at a time. I don't drive the truck in the winter, so after parking the truck in the garage I opened up the dash again.
So tonight I think I fixed the heater/ AC problem.
I have not had heat or AC in a few years, so I changed the: Coolant, rad cap, thermostat. I could see that the AC was cooling something (ice maker/ cooler) makes ice in minutes, and the rear heater was blowing lots of heat. But the front had no heat or AC. Last year I figured it had something to do with the cable and bracket on the firewall. So this summer I un-hooked the cable and manually moved the coolant mixer thing open and closed on the firewall. But still no heat? Changed some parts, flushed the heater core, and still no heat. Well tonight I got into the dash and was checking the Air Mix servos and noticed it was only moving a little. So after trying to move the cable up and down on the firewall, I realized that the cable also works the servo on the inside with same type connector as on the firewall. So I removed the cable on the inside of the dash also. Now it looking as if all the servos are moving fully open and closed. I really think the heat will work now. But I have to get the truck back together and pull out of the garage before I can check it.
Long story for a maybe fix, but if you are like me and reading everything on this site trying to figure out why your heat of AC isn't working. Any info is helpful.
[URL="http://s914.photobucket.com/user/meafordmike/media/IMG_3010.jpg.html"][URL="http://s914.photobucket.com/user/meafordmike/media/IMG_3009.jpg.html"][URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3009.jpg"][URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3009.jpg"][/URL][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3011.jpg"][URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3011.jpg"][/URL][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3007.jpg"][URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3007.jpg"][/URL][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3006.jpg"][URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3006.jpg"][/URL][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3004.jpg"][/URL][/URL][/URL]
While I got a post on the go, I have a question??
I haven't had hazard lights (four way flasher) since I owned it.
Tonight while the dash was open, I replaced the flasher relay, and hazard button. Still nothing? any ideas? when I press the hazard button the turn signal lights stop working but that’s it, no hazards. I checked the HAZ/Horn fuse also. I figure I have a wire messed up somewhere, but I am at the end of my electrical skills.
Last question.
Does anyone know if the interior light off the 80 series is shared with any other Toyota? I have a junk yard near, and need a new interior light, but we don't have 80 series around.
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3015.jpg"][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3014.jpg"][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3016.jpg"][/URL]
[URL="http://i914.photobucket.com/albums/ac346/meafordmike/IMG_3013.jpg"][/URL]
So, what end up being the problem? Seized cable? Just taking off the inside end od the cable, then putting it back on? Glad to hear that you got it working. I've been searching MUD for about 12 hours so far. A lot of things checked and tried, but still no heat. My cable in the engine compartment is stuck, and but the valve works. Thank for the thread.
