Can someone who has recently replaced this gasket confirm (or not) that this is the proper gasket for the heater pipe above the exhaust manifolds?
The parts diagram is vague and doesn't match the nomenclature. The (2) gaskets in the overhaul set both matched the pipe hole pattern, but since the oil cooler requires (2), I assumed that's what they were for. However, there wasn't (1) gasket to use for the pipe, so I used one of the (2) instead, and of course, it's leaking.
For reference, here are the same gaskets on the oil cooler diagram:
My OEM headgasket set had two of these and none of the (1) part I would have thought I needed, plus a few extras I couldn't identify at all.
