heater NOT hot
hey guys, i did a search on this topic but i didn't find any useful ones... i might be blind, who knows.. lol
anyway i did see the FAQ thread about the water valve mod (i posted a reply on it too- no reply yet).
it seems like when i switch my temp lever (in the dash) from cold to hot, it barely moves the cable. so i disasembled the cable from the valve and just turned the valve itself in the OPEN position (allowing hot water to pass through right?).
still, all i get is somewhat cold air blowing in the cabin!!
i set the water valve all the way open OR closed and pull the temp lever on the dash all the way to hot... it still blows NON HOT AIR.. any help or insight would be greatly appreciated :)
Humm, is this something that just happened? I don't know where you live but most of us have been using heat for some time now. How's the rear heater putting out?
Does it sound like the blend doors in the HVAC are moving okay? I presume your heater control system is all manual, no electronic blend door switching system and clearly no electronic heater control valve.
Not that I'd jump the gun but it might be a clogged heater core. which is not that big of deal if it is the case. I've never had to clear a core on an 80 but have on 60s.
To find out just locate the IN heater hose to the core and feel it to confirm it's warm. Then the outlet should be right next to it on the firewall. If it's cool or cold you don't have water flowing through it.
If that's the case, when the motor is cold, duh, you should be able to take out not too much coolant as the heater hose if very high up on this truck. Disconnect the heater hoses, hook up a fairly long section of heater hose to the core's outlet and and get the old garden hose hooked up and blow some water in and see if you get any flow out and what it looks like. You might want to hook up a long section to the inlet too as if it's clogged you could have some very very nasty water coming out of it that you'd want to wash off the truck right away.
The 60 I had to do this on, had nice green coolant in the engine, but the heater core blew out rusty, mucky water for a very very long time. I think I back flushed it for at least thirty minutes. It eventually came out clean, and then blew hot hot heat from then on and never had another problem.
Now I'm not saying this is your issue so I'd check everything else first but it sounds like a strong possibility. Especially if it sorta warm and warmer on the lowest fan settings.
On the LX450 I purchased in Nov, the PO informed me that the lack of heat from the heater was from a clogged heater core (told by his mechanic). So, when I took it to my mechanic for a once over I asked him to back flush the heater core for me. It cleared the core and now I have MAJOR heat from the heater, yay :). Hopefully this is all your problem is because it was a cheap fix, unlike replacing the heater core - ouch! Good Luck!
