Heater Issures
Camden, SC
I have a 92 LC and have recently developed heater issues in the front vents. My rear heat vent is working fine and after a while it will eventually heat the entire truck. Front heat only blows cold air. What's annoying about the whole this is that I have no defrost. What gives?
Heater valve. Right above the engine on the firewall. Odds are the valve itself isn't working or maybe the linkages behind the dash are broken.
I am replacing mine right now.
Have someone move from cold to hot and see if it moves the linkage on the valve. That should eliminate a linkage problem.
I don't think it would be the heater valve. This controls both the front and rear heat at the same time(can't spell simutainiously). So if the valve was toast both heaters would be compromised. I bet your heater core is plugged up. You could try to flush it, maybe use muratic acid to clean it out.
I was thinking the same thing, but did not know how the hot coolant was split between front and rear.
Was going to do a rear heat bypass today since I thought it was leaking, but after inspection I realized it was just rear diff fluid that looks green with the led flashlight I was using. Anyways, between mud and several trips to the garage I noticed a few things that will come in handy for us lucky 3fers.
The hose routing is different than the 1fze engine, substantially so. Bypassing the rear heat is very doable, just a little different. And if you do decide to keep rear heat and fix the leaky lines, looks simple and no need to drop the tranny. Anyways, heres a pic i snapped this morning, its the heater valve, with the output line splitting to the rear and front heat. The valve controls the flow, while the dash switch controls the fan, I think.
