Heater input needed
I want to eliminate my heaters. Do you guys think this is a good idea? I'm planning to loop the system in the engine bay so that the coolant doesnt have to travel under the cab and through the dash. I live on Guam and heater no need.
It's pretty easy to do. There is no need to do any plumming. The coolant flowing to the heater cores is controlled by a water valve in the engine bay at the top and just right of centre of the firewall. The valve is actuated with a cable control. Just disconnect the cable from the water valve on the firewall in the engine bay and shut the water valve manually. This will stop the coolant from entering the cab and obviously the heater cores. Should take you about 3 seconds, 6 if you include opening the hood.
Just ensure your coolant is in tip top condition as stagnating the fluid in the cores could promote and sedimentation and corrosion if your not using a quality coolant with a good rust inhibitor. Cycle it from time to time to ensure the cores stay clean.
