Heater Fuse Blowing
Plano, TX
I have a 1973 FJ40. The heater fuse blew last week for the first time. I replaced it. It held for a day. Now it blows a fuse as soon as I turn the key to start it. That fuse also provides power to the following gauges: gas level,oil pressure and temp. I am sure it's a short somewhere. Thoughts on where I should start looking first? Thanks owned this one since 1973.
Start it.... what? Start the engine or start the heater?
Does it blow when you turn the key to the "on" position when the heater is off?
Try to eliminate when it happens. That way you can rule out some circuits.
Rudi
The Heater fuse feeds:
The gauge cluster, heater blower switch, back-up lights, brake warning light and transfer indicator light.
Follow the blue/red from the fuse box. There is a splice. One wire (blue/red) stays under the dash for the cluster, heater blower switch and the brake warning light.
The other blue/red goes through the firewall to the back-up switch and transfer indicator switch.
The easiest way to find the problem is to take out the fuse and hook up a test light to the fuse holder clamps. Remove the barrel connector to the gauge cluster because this cluster is drawing current as soon as the key is in the "run" position. As long as there is a short the test light will lit up.
Start disconnecting circuits. Disconnect one by one wires to circuits.
Or..... as long as that test light lits, move, shake, lift, push, pull the wires under the dash and on the other side of the fire wall until the test light goes off.
It can be that that blue/red wire is making contact to ground by chafing. Maybe a bad grommet in the fire wall or so.
Good luck,
Rudi
check the reverse switch on top of the transfer case. mine wore threw and did that.
Bingo! Thanks Steverb.
Wire was loose. Was tripping fuse when I put in reverse. Didn't even have to take the skid plate off. :)
All back to normal.
