Heater doesnt' work
Buckley, WA
The blower motor works fine but no heat. The rear heater does blow hot air though. What gives??
Maybe one of your water lines is plugged up going to the forward heater sub assembly(radiator), you got hot water going to the rear sub assy so the main heater water valve assembly is at least kinda working.
I'm not sure if the heater water valve assembly is selectable and can divert water to either to front or back or both, but that may be it too. Haven't messed around with mine, so I dunno:meh: Also, check the linkage of the knob that goes from heat to cold
Put on a coat:grinpimp:
If it was me I would... but seeing its going to be in the 20's and 30's in winter I doubt camping is in with my wife if I don't fix it.
I gotta make sure mine is working too. I missed the North meets South ride, so the next one i might be able to make will be winter time:p
If you have used stop leak that crap probably plugged it up somewhere. Take the hoses off at the fire wall and have a look.Some of my lines were pretty clogged. Maybe try to clean it out with a garden hose.
