Heater core woes
Seattle, Wa
I've got a serious problem with heater cores lately. I've been through a total of 4 in the last 6 months and can't figure out the problem.
The first core looked like it was original and when it started leaking I didn't think anything of it. The radiator was new when I bought the rig, so I figured that the radiator had just gone first and it was the heaters "time".
I was able to get a new core and replaced it last summer, but never really had water going through the heater until this last fall. Within a month the new core was leaking. I checked the core and it looked to me that one of the welds (brazed) had failed. I chalked that up to bad luck. The second new (third total) core came and that one lasted about a week before it literally exploded. The fin supports (for lack of a better description) on the outside edges of the core had come off of the main assembly and the coolling fins looked like an expanded accordian. At this point I was thinking I had some really bad luck, but I dismissed a pressure problem because I hadn't blown off any hoses. I have had the third new (fourth total) in for about 2 months and today it started leaking.
Are there any ideas on how I could be overpressurizing the system without blowing off the hoses? I have an expansion tank for the radiator that seems to be working. The radiator/heater hoses are all new. The engine is running at normal temperatures (about 1/2 on the guage). The radiator cap is a 14-lb release. I have not back-flushed the system because after three drains for the replacement I didn't think it would be necessary. Could there be a blockage such that I am only pressurizing the heater part of the system and never the radiator/cap?
Thanks for any help,
I know I lost my heating system one part at a time years ago on my old firebird. First the radiator, then the water pump started leaking and then the heater core...FOund out I had a bad Cap on the Radiator. YOu say that the cap releases at 14 pounds, is that from having it tested? I am not certain if 14 pounds is high or not, but maybe others have better ideas.
14# is stock for most vehicles. I think 13# is actually listed as stock for an F/2F engine. For $5+, you might try replacement of the cap.
Personally, with 2 cruisers over almost 30 years, I've never had a problem with a heater. I can't imagine having one fail, short of corrosion from not running coolant or performing maintenance once in a while (I'm pretty delinquent about normal maintenance after all these years, myself).
First get your cap tested for free at the parts store and that'll tell ya if it was a culprit. Then buy the new one if need be. Mine was tested at 9psi yesterday and the rad guy told me to keep it because of the repair I just had him do to the alum rad, in an attempt to not blow out the weld and epoxy job.
Have a rad shop test your next new core prior to installation to see if it holds pressure without exploding. Or just pressurize it with your air compressor to a regulated psi ( I guess around 20 psi or so ) and dunk test it for a while to see if it holds.
Get a tester or have the rad shop put a tester on your system at the radiator cap opening and on the pressure line going into the heater core when it's pressurized to see if it's abnormally high.
Just a couple steps you could take in your quest. ;)
Welcome to mud!
:beer:
Thanks for the help everyone. I went out and double checked the rad cap, and it was listed as 13# like spotcruiser said. I pressed on the plate to make sure that the spring wasn't binding, and everything seemed to be in order. I'll see if I can't find someone to test it for sure.
Does anyone know what a normal running psi would be? I'm guessing that if the cap is around 10# then operating should be 5 or 6. Sound about right?
I'll post if I find anything mind boggling.
Thanks for the welcome Hawk ... I look forward to bouncing questions off folks. :cheers:
