Heater core replacement threads
Decatur GA
I was looking around trying to find a youtube or something on replaceing the heater core (front). I am getting a little antifreeze leak on the floorboard and the condensate drip from the AC on the ground stays for a few days making me think it has a little antifreeze in it too. It feels like water and does not smell like antifreeze, but it is not evaporating like normal condensation water does. Before I delve into this, I thought I would try and watch some links on removal techniques that might be specific to my 1995 80. Every car has a different bolt or hose that is a pain in the but so helpful tips are always welcome.
I replaced heater core in my 1991 a couple of years ago. Major PIA job as it's done from the passenger compartment. Entire dash must be removed, down to the frame. Follow the shop manual as there are many hidden bolts. Take a lot of pictures and organize what you take off, with fasteners, as you go. (I even replaced the burned out Drive bulb "while I was in there".). Good luck and take it slow.
I was affraid of that. I assume the 91 is going to be very similar? You mean the bulb for the drive "D" on the dash? Mine is out too. Might be a good time to replace the radio. Will it make it any easier to fish a new antenna cable? I am going to take the auto one out and install a fixed marine to my disappointment.
Your 95 should be the same as my 91.
Yes, the "D" bulb on the dash; although I didn't have a new bulb so I swapped out the one from first gear.
Yes, a good time to deal with the radio and antenna.
BTW, your AC system will get depressurized when you access the heater core, so you may want to deal with that early on to save the AC gas.
That sucks about the AC. I was not planning on that.
