Heater Core hose bracket tightness
Atlanta
Finishing the heater install and noticed that the Toyota hose (as well as the standard NAPA etc. hose) does not get clamped all the way by the wider brackets ( the hose clamps do fine).
They wiggle and rattle a little.
What is wrong with my install or is this somehow normal?
Example Clip
Could anyone please confirm that this bracket can indeed tighten down all the way onto the hose and/or wire clamps? Mine is shy about 1mm for some reason when tightened all the way and wiggles around.
Mine fit snugly. I used Gates green-stripe hose, which does run a bit thicker...likely helped it match more with the (assumedly) metric variant Uncle Toyota used.
Could either look for thicker hose, or I'd probably just tuck rubber strip in there as a shim to take up the slack.
Only bit I can think of is that they degrade pretty quickly over time. Whether it matters here, not sure.
I had some leftover rubber roofing that was handy for making gaskets and such...an old bicycle inner tube might do the deed too.
