Heater/cooling system issue
Colorado Springs, CO
Got a problem here. 93 FZJ80, 260K on the clock. I've recently had intermittent issues with the heaters - no heat from the front, very little from the rear. Blowers are fine. Temp gauge reads normal. Eventually it will start working again for no apparent reason. Maybe after a bit on the same drive, maybe after being shut off for awhile.
I've also noticed that if I drive it hard while the heaters aren't working, the temp gauge will climb rapidly until I back off and idle. Temp gauge is stock. If the heater is working, this doesn't happen. This seems like a bad thermostat maybe?
Other info - radiator is full, though i had to add about half a gallon last week. Top of the core was visible. Drove it skiing this weekend - 300 miles on highway with no problems, no coolant loss. No leaks when parked. But now no heater 2 days in a row.
About 3 months ago the hardline to the rear heater failed. Replaced with OEM, refilled and burped the system.
Radiator is about 5 years old. Good quality 3 core brass, but not OEM. I am running a modified fan clutch.
Had trouble overheating last August in UT pulling hills in 100 deg weather, heavily loaded.
It's also developed a rough idle recently. Going to R&R distributor cap, wires plugs this weekend. Will also check with the block test kit. Oil & oil cap looks fine. Head gasket is original AFAIK - I've had it since 104K.
Any other ideas/suggestions?
So much to deal with. Start simple. Best thing you could do is get a real temp gauge. The factory one has a dead zone from about 170 to 220. Your temps are probably flucuating wildly but you don't realize it because of the factory gauge. The heat, front and rear also are part of the cooling system so if your having issues with them your also having issues with cooling. There is a massive number of threads on mud covering every type of overheating issue but it helps to have a better understanding of your own system.
Look up intermittent heating. Could be flow problems, could be duct door problem
1944213
:frown::frown::frown:
