Heater control valve assembly issues
Athens, GA
I was replacing my heater control valve yesterday, and Murphy's law was in full effect.
In less than one minute I managed to somehow spring loose the actuator arm for the valve, then drop the valve assembly down the engine compartment into my full oil drip pan on the opposite side of the engine bay.
Obviously I have been able to clean the valve, but I cannot find the actuator arm- I think it fell into the wire/hose cluster from the transmission to the engine. I've fished around with one of those antenna magnet things, flashlights, and my hands where I can reach. Any tips on what I can pull first/easiest to get to the area? Maybe the center console and then the Trans access plate in the floorboard. I'm planning on using a leaf blower to try and knock it loose.
Does anyone know a part number for this arm? It's the lever between the heater cable and the valve. I can't find it on any diagrams, and my dealership couldn't either. It might just be easier to buy a new one now.
Thanks!
If you can't find it. Buy a cheap Dorman brand from the local parts store or your favorite online retailer. Use the arm out of that.
Or junk yard. Pretty sure the arm and valve out of my second gen 4Runner and my 80 are the same. I've not done a side by side comparison, but I've held them both in my hands at different times.
If the 2nd gen 4R works, then the 1st gen 4R and 1st gen Taco are the same valves as well.
Sent from my Nexus 5
