Heater/AC control problems...Any simple fix?
Perry Hall, Maryland
I apologize if this has been posted before.... I am having a problem with the heater/AC controls in my 97 FZJ80. During the winter months the beast is fully warmed up and will suddenly start blowing cold air even though the temp slider is set to full hot. Recently she has been doing just the opposite while running the AC (suddenly blowing hot air while set to full cold AC). With a simple slide of the temp adjuster, the problem goes away during the AC mode. In the heat mode, I have to play with the fresh/recirc button to get heat back.
Has anyone encountered the same issue and is there a fix for this other than replacing the entire dash control cluster?
Thanks,
Shark
My first suggestion....pop the bezel and make sure ALL of the HVAC connectors are tight.
On my '97 FZJ80 AE the temp options were full hot or full cold. The dealership told the PO that it was a $300+ fix ($120 part + labor) so he never screwed with it and I didn't either until someone with the same problem posted up a thread. Come to find out that person had recently had a stereo installed just prior to his acting up.
Well, long story short , the "problem" was a simple connector...:doh:
Oh, and this was on rigs with AND without automatic climate control.
Here is the thread
https://forum.ih8mud.com/showthread.php?t=162158
EDIT: Just noticed your sig line and I'm feeling pretty confident you will find this is the problem :cheers: - If you run into problems and can't figure out what goes where (although IIRC it is hard since most of the connectors aren't the same and therefore it is hard to plug things up wrong) shoot me a PM
I'm pretty confident all of the connectors are secure, but I'll double check them as soon as I can find some free time. You see, everytime I go to work on my truck, the girlfriend starts up with those all too familiar words.... "When are you going to fix some of the things around the house?"
Thanks for the ideas and I'll get back to you soon.
BTW.... No climate control... Thank goodness...
Hope it is that simple of a fix as it was for me :)
As for the climate control, I was futzin' with mine the other day sitting in traffice (I never really paid much attention to it) and I noticed that sliding the temp control gives you an almost infinite number of fans positions :rolleyes:
The colder you ask for the higher the fan runs and it will gradually, with numerous steps up or down, adjust the fan speed as you move the temp slider...IIRC there were at least 3-4 "steps" in fan speed between each major speed that you have a button for. Total HVAC bling :lol:
