Heated Wipers
Nay
Colorado
Installed a set of heated windshield wipers over the holidays from Northland:
http://www.hotwipers.com
The wires run through the engine compartment and then through the firewall, zip tied as needed. I wired it up to the stock switchbox where the side mirror controls are by converting a stock placeholder to fit the switch. I powered the switch off the ignition line coming into the side mirrors, and it is a fused system.
The wipers are supposed to retain at least 50 degrees Farenheit down to some obsecenely low temperature, and in our last major storm they performed excellently (absolutely no snow or ice buildup on the blades or windshield).
My only disappointment stems from what seems to be commonplace with aftermarket blades on the 80 - they don't conform perfectly to the windshield just as the last set of "covered" blades did not conform perfectly. Not a major issue for me since I don't live in a rainy climate and my wipers really don't see all that much use, and the ice buildup prevention works perfectly so far.
First pic shows the wiring, second shows the switch placement (red switch on the left). By wiring to the ignition power, the switch is only operational when the ignition is ON or ACC. Mirror operation is only occasional and brief, and not likely to occur at the same time as wiper heating, so no issues with excessive draw on that circuit that I can determine.
Thats crazy! I never would have thought something like this existed... but i guess if you live in a place where you get a lot of snow, you have time to think up inventions like this........
very clever! :idea:
Just out of curiosity why did you choose heated wipers vs. heating the washer fluid?
I am wary of those heated washer fluid systems in terms of exacerbating small cracks with a 140 degree blast of hot water in very low temps. I had a case where the windshield on my old truck was hot from the high altitude sun and snow melted off the roof and onto the windshield, cracking it so badly I had to replace it. It was so bad I thought I had been vandalized until I realized what had happened.
Plus, washer fluid runs out - this seems to be a much more reliable system for distance travel in unexpected weather. Subes come with heated wipers these days I think - they make good sense as long as they are durable.
Nay
keep us posted as to how it works out for you. It looks like it should work out well.
Do you plan on disconnecting and storing the heated blades and wires in Spring?
What about eventual paint/ wire damage where the wires chafe against the edge of the hood and trim panel? I think it would be advisable for them to go through drilled holes with rubber grommets.
I recently bought a new RAV4 Ltd V6 4wd for my wife, and was disappointed to discover that the Canadians get an electrically heated panel on the windshield at the resting spot for the wipers (controlled by the rear defroster switch), but the USA models do not. I guess it never gets cold below the border...?
The wipers use a normal composite blade that costs about $6 to replace. We get so little rain here outside of late afternoon summer thunderstorms (hailstorms as often as not) that wipers don't see all that much non-winter use here.
I am going to watch the wire movement and see if it rubs - I set some slack so am not getting contact, but agree the grommets would be a good idea. I am actually going to be doing one of the poly bedliners on the entire body so really the only issue will be wire durability. There is a heavy outer casing and two cased wires inside, so I'll have a lot of advanced notice before I have to deal with any issues.
I don't know why all vehicles in North America don't have some sort of heated system to prevent snow/ice buildup. It is something everybody in snowy climates deals with, and can be a huge safety risk. There is little IMO that is more dangerous than pulling over on the interstate in slick conditions to get out of your vehicle to remove snow and ice from the windshield and/or blades totally exposed to the traffic that continues down the road probably driving too fast for the conditions with inferior equipment.
Now I just needed heated side mirrors :grinpimp:
I thing FSUSTEVE has a set of these as well :D
