Heated Steering Wheel
'Merica
Has anyone added a heated steering wheel to their rig? I'm currently searching for my first uzj100, so I don't have any experience with them, and I haven't been able to find any threads on it.
Does anyone know if the spindle or slip ring are much different between LC/LX models? I come from a BMW background and you could retrofit heated wheels with a little bit of work and mixing and matching different parts from different models.
Thanks!
Bump?
Could be possible that the GX has the same splines as the LX? I've seen other Lexus wheels fit so maybe they're all interchangable
Newer GX and LX wheels have the heated wheel function, but not sure if they fit
Pretty expensive to retrofit, even on a GX. And then, it's only the leather part that's heated.
That GX retrofit on the thread you linked didn't even work out in the end despite a ton of work. If you can't even make a GX heated steering wheel work on a same generation GX then it sounds like more trouble than it's worth to try to make it work on a 100.
I wonder if a heating element can be put under the leather of the stock steering wheel and just run some wiring to a custom dashboard switch...
Wouldn’t you still have to find an unused pin on the existing “clock spring”, repurpose a pin on the existing “clock spring”, or find a new “clock spring” with more conductors, in order to wire the heating element in the wheel, and still be able to turn the wheel without breaking your wires?
