heat shield - necessary?
92LC_good2go
returned from walkabout
NJ
Questions about two things ---
Finally did something about that rattling old heat shield on my FJ80. It was rusted away so badly that my mechanic doesn't know how it was still actually hanging on.
Once that was removed, no more of that aggravating high-pitched metallic rattle.
I asked the mechanic if he could get me another, but he insisted that the rig "doesn't really need it anyway", why bother, it has "no good reason for being there". His reply to my next question as to why it was on the rig to begin with, if it wasn't there for any good reason, was that "foreign manufacturers love to put that kind of stuff on, but it's really unnecessary".
1) Is he correct? Is it surperfluous? Or do I need one (or should I have one)?
Now, without that godawful loud metallic rattle... I hear what I didn't hear before. (of course :rolleyes:)
A deep rumbling rattle starts up whenever my cruiser is in Drive but stopped (as in at a red light). As soon as I goose the as pedal (while firmly holding the brake with the other foot), the rumbling rattle goes away. Or, if I slip it into Neutral, it also goes away immediately.
As soon as I start the beast, the rumble/rattle starts. In reverse, and in Drive but on brake, it starts up.
But if it's in Park, not so bad. In Neutral, no sound at all, nor in Drive but with feet on gas & brake.
2) Any bright ideas on what it could be, now?
And, if the answer is that I need a new/another heat shield, any ideas where I might find one? (Local Toyota dealer has told me more than once to quit calling them for parts, they haven't got any for a Cruiser as old as mine - 1992. They just keep trying to sell me an FJ.)
Kinda sounds like u-joints...just my $0.02
Thank you.
Should I bother to replace the heat shield? (if I can get replacement) Or not?
How important is that?
Thank you.
Are you talking about the heat shield near the cats? As I understand it that is there to protect the factory running boards and keep them from melting. So, if you have removed the running boards then no, I don't think you need it.
If you are talking about a different heat shield then I don't know. If you really want a cat heat shield I think I've still got the one I removed from my '97 LX when I put on my MetalTech sliders - rust free but not sure it will work on a '92 - but you could inject some "pink panty" DNA into that '92 :D
U-joints aren't in motion when the wheels are stopped so I don't think that would be the cause. Of course, I don't have a better idea :D
What heat shield are you referring to?
Ok
here we go .
Heat shield is not needed Im sure anyone who has a fj80 in the rust belt will tell you its been long gone . Mine was removed by oldman winter and the DOT over 6 years ago.
Next the ruble you are hearing is that the hanger on you exhust system are most likey rotted and or broke . There are 3, one at the cats, one on the back of the muffer and one at the tail pipe .
With it in gear the systems moves some and is most likley hitting the floor or frame.
Find a shop that will fix the hanger and you'll be good .
Yes, I'm talking about the heat shield near the cat converter. Sorry. I didn't know there was any other besides that one. :o
I haven't yet removed the running boards, but they're next to go. The PS running board is loose; one of the bolts (or 2?) have broken off...
No, that's not what's rattling/rumbling. At least, if it's part of the prob, it's not all of it.
I don't mind a "little pink panty injection" into my old 80 :lol: and I doubt my 80 will mind, either. ;)
Will a cat converter heat shield from a 97 LX fit on my 92 FJ80? Does anybody know?
Corsair23, can ya hold onto that shield a little longer while I try to find out, please? Thanks.
Ok
here we go .
Thanks. I live mostly in NJ (and that's where my cruiser is)... so I know all about rust belt issues, believe me. :grinpimp:
I welded the hanger (the figure-8 hanger) where the pipes leave the cats over a year ago... June 2006. That's still good; I checked. (It aint pretty, coz I'm no great welder, but it's done and still holding.) The one at the tail pipe also seems fine. I doubt that's the problem.
I'll have to check the one behind the muffler... Dunno if I've ever bothered to notice that hanger before.
But I don't think that's it (or all of it) because the sound of the rattle is hard to pinpoint, but when it rumbles, I can feel it underneath my feet - when I'm driving. I'm the only person who ever drives my 80. I don't even let my husband drive it. So I can only speak as what the driver would notice.
I think something up front - underneath - is part of the problem.
I also suspect, since the cruiser has spent it's entire 15 years here in Jersey, that it's probably more than one thing.
Well, I'll check the hangers again, anyway, and repair if I find something that needs repair. Thank you.
You know, I'm not sure there is another one myself :confused:. But now we know we are talking about the same thing :D
Don't know if it will fit or not for sure, but if you are dumping the running boards anyway then I would forget about worrying about putting a cat heat shield back on. If your running boards are in that bad of shape then you're probably not going to try and save them so if they melt a little in the meantime no worries.
The running boards are super simple to remove (at least on my '97 LX they were). Two bolts up front, 1 bolt and one nut in the middle, and 2 bolts in the rear. Assuming yours are not rusted on then 15 mins max and they're off.
Of course, if you really want the cat shield it is yours. I've also got a set of LX450 running boards as well with minimal rust (CO vehicle) ;p - something tells me though that those might not be a straight bolt on deal though between the years.
Anyway, if I have still have the cat shield floating around somewhere in my garage, and you really want it, it is yours...I'm a typical male and rarely if ever throw away any Cruiser parts :)
:lol: I don't think there is. :lol:
NOTHING on a '92 vehicle in NJ is "not rusted". Nothing! :doh:
Mine have 5 bolts, I'm pretty sure. The rearmost one or two is what's rusted & broken loose on mine.
I'd rather replace my running boards with rocker sliders. Perhaps this is the Good Excuse... but I dunno. Timing's not there: total restoration of my cutty & painting interior of my house. So I think my old running boards - or those which I may be able to pick up for not too much money - will have to suffice.
If you find the cat heat shield, and you want to rid yourself of the running boards, and you would like a few bucks for the items -- then I'll seriously try to find out if either will fit my '92 cruiser. PM me. Thanks. :)
Does anybody know if either the '97 LX running boards and/or the cat shield will fit my '92 80?
The cat shield will not work as your cats are side by side and the 97 LX are one after the other .
As for the running boards Im not sure since the 92 and the 96 have different sized flares and mud flaps so they newer style maybe wider also .
First, I thought you were talking about the heat shield in the engine bay by the manifold (some people use it as a grill I'm told :))
Second, I really don't think you'd want to pay for shipping running boards from CO to NJ. You'd be better off finding some locally or just putting the money toward sliders.
Just my $0.02
Thank you for the info, Koffer.
Ah, well, thanks anyway, corsair23. :)
Guess this means that I need not worry about replacing the cat heat shield. And the old running boards will have to do for the present. Once the cutty is finished, I can sink [more] money into the cruiser. :crybaby:
Thank you, everyone. :)
The heat shield on our 80's (91-92) helps out a bit... The floor under the driver's seat, if you haven't noticed, will get really warm and toasty as the cats heat up to operating temp.
My suggestion? LOTS of insulation.
That is probably a really good point we've missed...The early years with the 3FE have the exhaust routed on the DS doesn't it? As where the later years with the 1FZ is routed on the PS.
Later years we get heat on the PS floor board etc. What does the heat shield look like on the 91-92 80s? On the later model years it is simply a flat metal piece mounted vertically on the body next to the cats, about the same length as the two cats together. IIRC it does nothing to shield the heat going up, just to the side for the running boards.
that is Funny! I haven't had to try the dealer for parts yet, but I did pick up an FJ! :)
The funny part is that IF I had to buy a replacement vehicle for my old 80, it'd be another Land Cruiser, or a LX -- not an FJ cruiser.
I need a lot more cargo space than the FJ's got.
A smart dealer sales rep should be trying very hard to sell me another Cruiser wagon; that's what I'll buy, eventually, whenever I must.
An FJ's kinda cute, but it's not nearly large enough for my needs. I rented one for a few weeks, to see what it'd handle like; not bad. But I barely have enough room in cargo with my FJ80, with the rear (3rd) seats pulled out.
So... wait... the cats in my '92 are routed out to the DS front floor area?
*sigh*
Guess I'll have to start searching for a heat shield. Dunno where I'll find one if dealers don't carry them any more.
Thanks for the info, anyway.
Can anybody please post up a pic of one, so I can see if I might be able to have one made? Thanks.
Stock 91-92 has LOTS of exhaust "heat shields".
1) One surrounding the lower part of each downpipe.
2) One on the lower firewall above/behind said area of downpipes.
3) Two part "clamshell" one surrounding the two cat's.
4) One on the body just above the cat's.
And a couple more further downstream.
Of the above 1 - 4, I think at this point I'm only running with numbers 2 and 4. Doesn't bother me...
Curtis
