I just found on my recently acquired 1971 FJ40 the heat riser cover and bimetal control are missing. Also the rod is missing. I don't know if it was removed or if it rotted away. If the rod rotted away, then what happened to the butterfly? My question is, has anyone run their truck without the heat riser. I know it's purpose, but I'm in FL so the cold is not an issue. But you have constant heat on the intake manifold.
Also if you do remove the hear riser. How do you close the holes where the rod was?
Thanks
Rick
1971 FJ40
1952 VW Split Bug
1997 Jaguar XK8
Thanks
Rick
1971 FJ40
1952 VW Split Bug
1997 Jaguar XK8
