Heat Riser Stop
high desert, ca
So I had an exhaust leak, go to look for it, and find it leaking from some loose stuff with missing bolts and a heat riser stuck in the cold position. Explains why it hasn't been running as good the last 2 runs.
When I was looking at diagrams to get part numbers for new gaskets, I noticed this little thing called a "Heat Riser Stop". Since my 55 came to me without even bolts between the manifolds in the heat riser area, this part wasn't there. Is this stop needed? Does it just stop the riser from moving too far in the hot position? If it is needed, could someone show me a pic of what it looks like?
I was thinking of sticking the riser in the hot position and blocking it off. We don't exactly have midwest type of weather here in southern california, so I'm not attached to the riser. If I use a piece of steel the same thickness as the original gasket, will this be too thin? It is an older pig, so I only have one gasket as opposed to the 2 with the insulator.
Thanks, may pigs one day rule the earth.
