Can anyone explain to me how this works on the 1FZ-FE. I suspect it may be malfunctioning on my rig.
Is it just hot air or exhaust gas ricirculation? Does it always recirculate or does it shut off at some point? What is that box on the side of the air cleaner housing?
That is the PAIR valve, in between exhaust pulses there is vacuum in the axhaust manifold the PAIR valve lets air in from the air cleaner into the exhuast to help the burn in the catalytic converters
the box on the air cleaner is a muffler the pulses woudl make an audible noise otherwise
interesting. i thought it was functioning in the other direction like a heat riser back in the day.
my lc runs great in cold weather all the time and in warm weather up until the time it reaches full operating temp then it gets a little sluggish and there is some knocking under light throttle. i thought maybe it was getting hot air off the exhaust manifold making it too hot in warm weather and causing pre-ignition.
We have tried numerous fixes to no avail.
thanks for the reply.
The purpose of the pair valve is to put more oxygen into the exhaust at warmup to help burn off the cats. It should not work when the engine is warm, except on deceleration. You can check if it is your problem by plugging the vacuum line off the intake that feeds it. There is also a test sequence in the Factory Service Manual.
I had FSM's for my FJ62 (avatar) but I have never picked em up for the 80. I'll have to do that.
Thanks for the explanations on the Pair Valve operation.
What spark plug are you guys using? I wonder if mine are a notch on the hot side.
“A cold plug will not materially cool down an engine's running temperature. (Too hot of a plug may, however, indirectly lead to a runaway pre-ignition condition that can increase engine temperature.)”
Mike, they did away with them in 96, so no need to worry. rdye, have you done the temp gauge mod? Your symptoms sound like an overheating problem. What plugs are you running and at what gap? I've only run the oe denso in mine.
I have not done a temp guage mod. Overheating and thus pre-ignition sounds correct for the symptoms. We just can't locate the cause. Temp guage is where it has always been.
Plugs are Denso K 16R-U per the owners manual. Gap per spec. (0.031?)
Anyone know what the next cooler Denso plug would be?
We (my mechanic and I) have tried also sorts of things and tested everything we can think of to try and eliminate the pre-ignition knocking I am experiencing in warm to hot weather and under light throttle. Everything seems to be working properly. We recently did a decarbonization of the engine along with cleaning the throttle body and IAC.
I would either mod the temp gauge or put a mechanical one in just to make sure. These gauges from the factory are pretty far from accurate. Even with the temp gauge reading in the middle it may be running hotter than "ideal". Before I did mine it read right in the middle all the time. Afterward it would get up to just under the red at idle, and I figured out I had a bad fan clutch. The first thing I would eliminate is engine temp, as this would cause the symptoms you desrcibed. If that checks out then I would start looking elsewhere. Have you double checked the base timing?
base timing was set back to spec recently
i had it retarded 3 degrees from spec temporarily to see if it would help the knocking.
it did not.
i'll look into the temp guage mod and check engine temp to see if its running too hot.
