Headliner replaced...
Awesome job. You must be a very patient guy to pull that off, so to speak.
Nice job!!! Those solid headliners beat the hell out of the soft flacid fabric jobs in the 94's.
I wonder if you could put a 95+ style headliner in a 94? :grinpimp:
That looks great. Do you plan on doing the pillars as well. It looks like there is a bit of contrast in the pics.
Well, here is the promised detailed procedure of Headliner reupholstering for 1997 Toyota Land Cruiser
Difficulty: :banana::banana:
Materials Needed:
- 3.5 yards (126") of 60" wide headliner material color of your choice to match
- 2 cans of spray adhesives (3M Hi-Tack 76)
Tools Needed:
- Basic hand tools
- 14mm socket and rachet
- Philip/flat screwdriver
- Clip remover
- Stiff bristle brushes
- Small wire brush
- Scissor
- Stationary Knife
- And of course, lots and lots of patience (MUST)
Part I. Removal of Headliner
(Removal process from front to back)
1. Remove both sun visors and both sun visor hanger hooks
2. Remove both front pillar grab handles and a grab handle on passenger side; also remove two plastic caps on the driver side (there is no grab handle unless you added them)
3. Remove the center sun roof control
4. Remove the rearview mirror but leave the screws in to hold the front center of the headliner board in place
5. Remove the sunroof opening moulding
6. Pop both front pillar garnish but leave the bottom clip back in place to hold the headliner board in place
7. Remove both front door opening trims
8. Remove both rear door opening trims
9. Remove both front seat outer belt shoulder anchors
10. Remove center pillar garnish but leave the bottom to hold the headliner board in place
11. Remove grab handles that connects to the front shoulder belt anchor adjuster to the headliner; HINT: Just remove a screw on the headliner side and let it hang
12. Remove both center grab handles
13. Remove both second row rear seat outer belt shoulder anchors
14. Remove both quarter pillar garnish but once again, leave it in place to hold the headliner from dropping
15. Remove both dome lights
16. Remove both third row rear seat outer belt shoulder anchors
17. Remove back door opening trims
18. Remove rear pillar garnish
19. Remove rear grab handles from the headliner
20. Remove three plastic caps (clips) from the rear headliner; HINT: At this point, headliner will begin to drop. I’ve used step-stool to set the rear end of the headliner to hold it in place
21. Call for help; you will need extra hands to remove the headliner without damaging it. HINT: I called my wife.
22. With extra hands, begin removing pillar garnishes from front to back while holding headliner in place. WARNING: Take all the time you need in this step. Make sure you have taken all the trim off so that board doesn’t have to be forced to be moved around.
23. Slowly navigate the headliner out of the rig and set it on the table that is big enough to hold it
24. Remove the rear speaker grills
Part II. Cleaning and installing the headliner material
1. First, peel and remove all old fabric. They will come off fairly easily
2. Remove the old material left over from the headliner board using stiff bristle brushes and small wire brush and use vacuum in between. WARNING: Be very gentle with the wire brush (It took me well over 6 hours on this step) What ever you do, take time and do not damage the headliner board. Also keep in mind, the final result will greatly depend on how well you prepare your headliner board.
3. Once all the old cloth and foam has been removed, place the material on the headliner board with equal excess on all sides
4. Now, fold the material back in the middle of the headliner board; Spay on the board and the foam side of the material with the aerosol and fold the material down to the board and firmly rub it with your palm. HINT: I did them in sections of 6”-10” across. Also, make sure you work the material into the contours of the headliner WITHOUT stretching the material
5. Repeat the process to the other half
6. Let it dry for an hour or so (At this point I was getting tired, so I left it over night)
7. With extra hands, flip the headliner board for final trimming
8. Original material was trimmed off right at where board ends. But I’ve decided to fold the edges in for cleaner finish and longer lasting result
9. Using a scissor, trim off around the headliner board leaving about 1” to 1 1/2” of material
10. Fold the extra material and see if it needs any extra trimming to clear the openings
11. Spay aerosol to the board and the material and fold them around the edges
12. Use the stationary knife to cut holes. For smaller openings I just cut them in cross to let screws to penetrate the headliner
13. When done sit back and have a beer and enjoy what you have just accomplished
Part III. Putting it back together
1. Replace the headliner the same way it came out but in reverse order. WARNING: Once again, be very careful when moving the headliner around for install.
:cheers:
This is a gem! I wonder if you could spray the old crusty foam with acetone or something to dissolve it instead of SIX HOURS! :(
Looks amazing! We did my boy's Dakota Quad-Cab, same careful process. Just take your time and be careful. His was cracked on a 1" wide area by the mirror. We epoxied it using a tongue depresser as a stiffener. Nice and thin and it worked perfectly if you have an issue with broken pieces.
