Headlights
Nghệ An
1979 FJ40. My headlights are not working but other lights are. I could have hit something while working under the dash and speedometer. Or in the engine compartment carburetor area as well as radiator wiring or hose area. It’s been keeping me busy. Now this!!
Seems specific to just the headlights.
Welcome To Mud Tommy !
Start by checking Your glass tube fuses in your drivers side kick panel fuse box , Simply replace the headlight fuse it may look good but can be detached inside foil strip
then if nothing still , reach up and look at your headlight switch connector make sure its pushed on , it can wiggle off and cause a short
let us know when u find the issue and apply the remedy-fix
I agree with RagingMatt as those are the first steps. If that doesn't work, get access to the back of the light switch and see if there's +12 coming into it and then coming off it to the headlights. That will tell you whether you are looking before the switch, after the switch, or at the switch itself. There are wiring diagrams for the light switch all over the internet.
