Headlights/taillights problem
A while back the taillights and sidemarkers on my 40 quit working. I checked the fuse under the dash and it's fine. The brake lights and turn signals still work. A while later, the headlights quit working. I have Snake Eye headlights, which have a turn signal incorporated into the bottom of the light, and those (the turn signals) still work. I'm thinking the headlight switch may have gone bad, unless someone has another idea.
How is the headlight switch removed?
Thanks
Could be a bad switch or a loose wire. Have you looked behind the dash panel to see the switch? As far as removing it, unscrew the set-screw from the bottom of the knob, unscrew the knob, take the retainer off and the switch should come off. Don't forget to unplug it first!
Thanks
Was your problem resolved?
