Headlights Not Equal Brightness, Real Time Help???
Athol, MA
I removed my Projector headlights and went back with the OEM housings using John Deere HIR bulbs. I get everything back together and the lights are not lighting properly. These are my symptoms:
High Beams Switched on: Both lights are very bright on the driver's side, but no lights are lit on the passenger's side and no blue high beam indicator on the dash.
Low Beams Switched on: Both lights on the driver's side are lit and as bright as when on high beam. Both lights are lit on the passenger's side, but very dim.
What gives???
If it matters I am running the factory harness.
Figured out the problem... Blown fuse under the hood. Don't I feel like an ass.
Why did you get rid of the projectors? I went to HID's with the stock headlight assembly and it looks amazing!!:cheers:
I've only had them on a month or so and one bulb has burnt out. I'm seeing if I like the beam pattern and light output of my JD HIR bulbs. I may go back.
Well if interested in HID's that are plug and play into our stock assembly I can get Pilot set-ups for $150.
