I have a 73 fj40 that I’m having issues with the high beams. Everytime I turn on the high beams the fuse blows. So I check continuity from the stalk to the headlights and that is ok . And then I look at the connection at the dimmer switch to main harness and I’m I little confused at how this works... the dimmer s plug has red and green (low), red and yellow(high), and white and black (ground). My confusion is that the white and black , when plugged to the main, is plugged into red and white. Which when looking at a diagram looks to be a hot lead... I also looked at a 74 project truck and that looks to be wired the same way. can someone school me as to how this works?
