headlight trouble
Tucson, AZ
I purchased the roundeyes 7'' halogen headlights. I took out the original headlight and found out that you have to use the stock headlight cradles. the headlight cradles are stuck these screws a in are very tight and I don't want to strip the screws because they are small and probably hard to find if I do strip them. Anyone have ideas on how to get the screws out?(without ruining them)
Pb blast the hell out of them and pray?? I always destroy any screw that is stuck then it finaly comes loose once I violate it with a torch, wire cutters, some kleins or a hammer and chisel. Then I have to find a new one. Home depot has helped me on a number of occasions with screws. Just dont ask for help.
Just did the same thing with the hella 100/55 lights, all screws were rusty and tight. I pb'ed em and the used vise grips on them, get them started slowly and work back and forth with more pb blaster. All came out without breaking. replaced with small bolts so I can use a socket next time. I also had to put de-rust on the bucket and mounting plate, repainted both and installed. Yeah every job on my FJ is a all day chore, about 3 or 4 hours to change headlights. They work great though.
Same problem with lots of the screws and bolts on the "72. I have had a bit better luck with Kroil compared to the PB.
Spray/soak the screws and give the stuff time to work. I try to give it a day to soak in; makes a lot of difference. Good luck
PB Blaster and time
